Activity Forums Adobe Premiere Pro Footage won’t sync correctly (different frame rates)
  • Footage won’t sync correctly (different frame rates)
    Posted by C. blake Davis on August 22, 2016 at 8:11 pm
    Here is the situation:
    Client wants me to edit teaching video with:
    DSLR Footage 1- 23.976fps
    DSLR Footage 2- 23.976fps
    Screen Recording 1 (PC)- 30fps
    Screen Recording 2 (Mac)- 30fps
    I selected the two screen recordings and did Modify>Interpret Footage and changed them to 23.976
    When I create a multi-cam sequence to sync everything together, the two DSLR cameras and the PC screen recording all sync together fine.
    For some reason the MAC screen recording does NOT match up, at all.
    I tried manually syncing in/out points using the Rate Stretch tool, but all the footage in the center is out of alignment with the rest of the project.
    This make no sense to me. Any thoughts or advice on how to match all of this footage together?
    C. blake Davis replied 10 years, 1 month ago 1 Member · 1 Reply
  • C. blake Davis
    August 23, 2016 at 12:09 am
    Thanks Dave, I’ve ended up individually exporting the screen-capture footage as new 24.976 files for the first lesson. This is working, but triples my render times for the remainder of the project (15 more lessons) :-/ It’s a ‘last resort’ option and I’m still hoping I can find something that doesn’t involve rendering wholly new files.
