Activity Forums Apple Final Cut Pro Legacy Footage to Mini DV
  • Footage to Mini DV
    Posted by Dan Newton on April 10, 2009 at 6:50 pm
    Hey
    I have a question — well two in fact, so here goes:
    1. When I export the video from final cut I want to convert the file to AVI – what do I use and how do I do it?
    2. how do i transfer my finished edit into a dv tape — I have a dv camera — what settings do I need to do to transfer my finished edit into the mini dv tape
    please let me know as this is quite urgent
    Many Thanks,
    Dan
    Steve Eisen replied 17 years, 5 months ago 3 Members · 3 Replies
  • Rob Grauert
    April 10, 2009 at 7:16 pm
    If you shot on miniDV, your project settings should be good to go.
    Before launching Final Cut, connect your camcorder to your mac via firewire. Turn the camera on to VCR/Playback/whatever your camera calls it. Launch FCP > File > Print to tape.
    I have a question though. Why do people always want to export to AVI? From what I’ve read, it doesn’t support as many codecs at Quicktime and Microsoft abandoned that format a while ago.
    Robert J. Grauert, Jr.
  • Dan Newton
    April 10, 2009 at 7:39 pm
    Hey,
    so to transfer my final edit to mini DV — do I need to put the line to the beginning of the edit —-
    should I put in put and out put points on the final edit — then I go to file — print to video and this box appears what should I enter —- then after I enter the info I press Ok — then what do I do — do I go to FILE – EDIT TO TAPE — will the full edit start to transfer to the mini DV Tape
    The camera will be connected to the computer set on vcr mode do I need to do anything else….
    in addition, for the AVI — where i live and work its quite needed — so could you help me out on that
    Cheers
  • Steve Eisen
    April 11, 2009 at 12:13 am
    You want print to tape not edit to tape. Look it up in the FCP help file. You do not need in/out points if you want your entire sequence output.
    You may need to hit record on your camera if you did not select automatically record.
    For AVI file, 2 ways. Export using compressor and go into your options and select avi. The other is by using Compressor. All your questions are in your help file.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
