Activity › Forums › Apple Final Cut Pro Legacy › footage & timeline
footage & timeline
Posted by Paolo Sartori on April 30, 2011 at 1:01 pmHi to all,
I want to start this post with all my greetings for all of you that in this years help me very much.
So…this is the question….I must to create a clip from two different kind of footage:
1) .mov 720×576 Apple MPEG2 25fps
2) .mov 1280×960 H.264 30fpsWhat do you suggest about the timeline in FCP?
And what about the codec? I usually use Apple Pro Res 422 for all my project….
Thank you very much!
PaoloJerry Hofmann replied 15 years, 5 months ago 2 Members · 5 Replies -
Jerry Hofmann
May 1, 2011 at 11:00 pmWhat’s the intended delivery format? a DVD? or a web stream, or?
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Paolo Sartori
May 2, 2011 at 7:47 amGood morning Jerry,
the final project must to be a dvd in standard definition and PAL anamorphic format because I would like to have the aspect ratio of 16:9 (for widescreen LCD).
I forgot one thing:720×576 PAL CCIR 601
1280×960 square pixelThank you very much!
Paolo -
Jerry Hofmann
May 2, 2011 at 12:30 pmI think I’d work in an SD PAL sequence setting (ProRes) and you’ll need to change the frame rate of the 30fps material to 25.
Once you’ve done that, you’ll need to enlarge the SD footage to fill the frame unless pillar bars are OK.
Jerry
Current DVD:
Paolo Sartori
May 2, 2011 at 12:37 pmThank you very much Jerry.
So: 720×576 PAL timeline @25fps ProRes. Right?Before to start to edit I’ve downsampling the 1280×960 to a PAL 720×576.
I know that the aspect ratio is different, from a 1,3 to a 1,25, but I don’t think that the processing will distort the images very much…what do you think?
Thank you!!
Paolo -
Jerry Hofmann
May 2, 2011 at 4:15 pmIf you’re happy, I’m happy!
Jerry
Current DVD:
