Activity Forums Adobe Premiere Pro Footage taken on uneven tripod! How do I correct without losing resolution?
  • Footage taken on uneven tripod! How do I correct without losing resolution?
    Posted by Bruce Pelley on April 1, 2013 at 6:54 pm
    Please help me minimalize the damage!
    My wife helps me film however over the weekend she did not have much success keeping the tripod straight and level which I only discovered after we were finished recording. We shoot a fair distance away from the stage so any deviation greater than 1 degree from being perfectly level is very noticeable when fixed in post.
    My goal is to not to sacrifice resolution, sharpness or pixel density in the process of attempting to correct the affected clips orientation, retain its’ 16:9 ratio & continue to fill the frame with the original image.
    Rotation generally requires scaling/stretching the image to fill the black space/triangles that result which impacts visual quality at least to my eye.
    I’d rather have a small black border around the entire frame then lose yet more detail.
    Apparently cropping doesn’t work as needed with rotation. The triangles/black space/gaps created by rotating the video still remain after the crop.
    What can be done to create a black border as stated above without having to zoom in on the footage?
    Are there any options?
    I’d welcome a solution!
    Thanks in advance.
    Mike Weber replied 13 years, 5 months ago 4 Members · 19 Replies
  • 19 Replies
  • Mike Weber
    April 1, 2013 at 7:31 pm
    Hello Bruce-
    Here’s one workaround. In your sequence, rotate the clip so that it is level. Then, nest your sequence into a new sequence. Apply the Crop effect onto your nested sequence, and adjust the top/bottom/left/right parameters to crop out the black areas.
    Mike
  • Bruce Pelley
    April 2, 2013 at 1:22 am
    Hi Mike,
    Thanks for your tip.
    I’m not familiar with the concept of nesting.
    How do I apply your recommendation?
    Would you be willing to walk me through it?
    Unfortunately there’s a lot I don’t know.
    Thanks for your time.
    Bruce
  • David Roscher
    April 2, 2013 at 5:52 am
    Check out Lynda.com they have allot of Awesome tutorials, that I totally love and rely on.
    To nest, you make your first sequence create the rotation and then either Render to another video file, or Place Sequence 1 into a 2nd Sequence.
    The way i learned this was with ‘Multi-Cam Editing’, via a Lynda.com tutorial.
    David
    Media Producer
    Editing System: Mac Pro 2008; 3,1 with 2×2.8 Xeon, 14GB RAM (Can’t wait to discover when a New Mac Pro Tower will be announced!)
    Nvidia 480GTx 1536Mb GDDR5
    Boot: Mercury Accelsior RAID SSD 480GB + project Drive
    Secondary: Velociraptor 500Gb
    2x1TB Element Back-up Drives
    6TB Media Storage
    Primary Edit tool: Adobe Premiere CS5 Master Edition & CS6 Suite (New User to this Suite on the Cloud!)
  • Jeff Pulera
    April 2, 2013 at 2:41 pm
    Hi Bruce,
    What is the source footage format, and how will video be delivered?
    If you shot 1080 for instance, but are not actually delivering in 1080, you could work in a smaller frame and then you’d have all kinds of extra resolution to play with, for instance edit in 720p and then scale away!
    Jeff Pulera
    Safe Harbor Computers
  • Bruce Pelley
    April 2, 2013 at 5:39 pm
    Dave,
    Thanks for reminding me about Lynda.com. I actually do not use the Multi-cam feature but typically dedicate 1 video track per camera & edit manually. In most cases that totals three.
    “Place Sequence 1 into a 2nd Sequence.”
    I’ll need to see what that means.
    Does that mean you take the source sequence, rotate, and then stack it with a clone of the original that wasn’t rotated?
  • Bruce Pelley
    April 2, 2013 at 5:44 pm
    Good point Jeff,
    Nice to hear from your again and always appreciate your help.
    Ultimately this is going to be scaled down significantly to SD for cable delivery. Yes, I admit the quality by then as broadcast is not good however I still try to produce the highest possible quality master.
    That’s just how I approach editing… do the best I can.
  • Bruce Pelley
    April 2, 2013 at 5:45 pm
    Footage is HDV 1080i.
  • Jeff Pulera
    April 2, 2013 at 6:49 pm
    Hi Bruce,
    One of the things I really like about editing 1080 footage is the fact that I can zoom in and re-frame a bit without noticeable quality loss, compared to doing it SD. I think sometimes we as videographers are overly critical of quality. I know I am!! As you are going SD in the end, perhaps you could get by with some fixing in the HD sequence and the viewer will never be the wiser. Your call though 😉
    Jeff Pulera
  • Bruce Pelley
    April 2, 2013 at 7:29 pm
    Hi Jeff,
    What do you think of the “nesting” approach as mentioned above by Mike and Dave? In your view is that a viable solution?
    Do you understand their concept?
    If so, would you be willing to run it through with me so I can learn?
  • Jeff Pulera
    April 2, 2013 at 7:39 pm
    Hi Bruce,
    Not a big fan of nesting, but here’s how it works. Say you have some clips cut up on the timeline, then you decide that you want all of them black and white, or all of them shrunk down as a PIP…or both!
    Create a New Sequence, then in the Project Bin, find the first sequence and drag into the new sequence. Shows up as a single “clip”, but represents everything in the first sequence. So now you can add any effect, scaling, whatever, to the one clip and it affects it all at once.
    So yes, this would work to crop the image after rotating, as described earlier.
    I normally work with an intermediate codec and would just render out that section as a new clip, but of course if you are working with an hour or two of footage for your stage event, then probably not the best idea! Personally, I’d be happy with rotating and then scaling 2% or whatever is needed rather than having a black border – if this is a two-camera event, the border will be a distraction when switching since it will pop in and out.
    I do hear horror stories of nested clips inside nested clips not exporting as expected and such. Not for me, don’t need the aggravation 😉
    Jeff Pulera
