Activity Forums Apple Final Cut Pro Legacy Footage Skipping HELP
  • Footage Skipping HELP
    Posted by Raymond Tuquero on April 24, 2008 at 2:32 pm
    So … I have worked with Final Cut Professionally for about 5 years now. And every once in a while I run into this issue with Capturing footage from a DVCAM and now a HDV Tape down converted as DVCAM. Just haven’t had a time to address this with outside knowledge.
    I usually pick another shot and move on.
    The issue is this: I am capturing HDV footage (Previously Logged) a warning sign pops up first about the fact that I am capturing NDF footage into a DF setting. Ok, I can change that. Now before I did ignore it and the tape captured fine.
    But now after capturing the Footage is skipping, yup Skipping. Awkward. Well, I did the usual troubleshooting thing.
    1) Check the Tape in another deck to see if TC or if the shot itself is skipping … NOPE
    2) Check the deck settings … I tried capturing in NDF and DF … NOPE
    3) Switch the Firewire Cable – NOPE
    4) Change the settings in FCP – NOPE
    5) Capture Now setting with no device control … mmm …. No again.
    6) I also Threw away the Final Cut Prefs to make sure there is nothing going on there.
    So, Does anyone have any other suggestions. I am in your knowledgeable hands. Because just about half the shots of footage I really need is doing that. … I have a while before the deadline. But I would like to get this resolved.
    My Configuration:
    MAC PRO – 2.8 Quad – 4GB of RAM
    1.5 TB RAID System
    AJA KONA Card
    SONY HDV M15U Capture Deck
    Tapes Recorded on a Sony V1 HDV Camera
    FCP 6.0.2
    THANKS FOR ANY HELP GIVEN … PLEASE DON’T BE SHY ABOUT ANY SUGGESTIONS. I WILL TRY JUST ABOUT ANYTHING … Except throw the computer out the Window. 😉
    -Raymond Tuquero-
    Houston Editor
    Jeremy Garchow replied 18 years, 4 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    April 24, 2008 at 3:04 pm
    [Raymond Tuquero] “Except throw the computer out the Window. 😉 “
    That is truly the only way to get rid of the problem, at least temporarily.
    Your raid system, is a firewire raid system?
    ANd the tapes you are capturing, the deck is doing the down-convert or you had those tapes down-converted?
    Is your tape DF or NDF?
    Jeremy
  • Raymond Tuquero
    April 24, 2008 at 3:45 pm
    Well … I for the Throwing part … I still like my window.
    As for the Raid, it is connected via Fibre Channel 4GB (Big o thing). And I am capturing footage by hardware downconverting … I am not a fan of downconverting then capturing. I feel footage done that way looses some info and doesn’t look as good as it was originally shot. The deck has a setting to downconvert the footage with either Crop Edges, squeezed, or with Black bars.
    Still pondering … I had an issue with this before … and it was back when the Raid had an update that messed up a setting change to screw with FCP. But the last update fixed that. Do you think it messed up the setting again?
    Hmmm … More diving is needed.
    Thanks for the reponse,
    -Raymond Tuquero-
    Houston Editor
  • Jeremy Garchow
    April 24, 2008 at 5:05 pm
    Don’t know about your raid. I was just making sure it wasn’t firewire.
    As far as the df/ndf, are your tapes df or ndf? if ndf, make sure to choose the firewire ndf device control setting.
