Footage shot at 24PA showing up as 29.97 in FCP
I shot footage on an HPX-170 at 1080i 24PA. When logged and transfered it shows up as 29.97 fps. When I add the clips to my 23.97 fps sequence the playback is choppy. For some reason when I apply the conform to sequence on the clips it will fix the problem, other times applying conform to sequence will not do anything to alleviate the problem.
Obviously I am missing something. Any help would be greatly appreciated.
