Activity Forums Apple Final Cut Pro Legacy Footage Pixelated when brought into FCP
  • Footage Pixelated when brought into FCP
    Posted by Rob Erobs on July 31, 2011 at 7:08 pm
    I created an animation in After Effects which was rendered with the Animation codec at 720*480, square pixels with no interlacing.
    I imported into FCP the Aspect ratio setting in motion is set to 0 and the sequence settings match the animation. (720*480 Square pixels, no field dominance.)
    I can’t get it clear. Please help me!
    Jerry Hofmann replied 15 years, 1 month ago 2 Members · 1 Reply
  • Jerry Hofmann
    July 31, 2011 at 10:19 pm
    Judge it externally on a video monitor, and also try looking at it at 100%. Does it still look bad?
    Might try a different codec. ProRes 4444 carries alpha if you need it.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
