Activity Forums Adobe After Effects Footage mash up
  • Footage mash up
    Posted by Balazs Szabo on February 26, 2016 at 10:36 am
    Hy, I have 2 footage of the same set that I want to mash up, but in the secound footage I have some camera moovement and rotation. I need the footages to be perfectly aligned, so is there a better way (plug-in, preset, etc) than manually position it frame by frame?
    Thanks for the help in advance!
    Chris Evans replied 10 years, 6 months ago 3 Members · 4 Replies
  • Tudor “ted” jelescu
    February 26, 2016 at 11:22 am
    Post the clips for us to better see the issue. And please explain what do you mean by mash up… Maybe not all here understand the same thing you do when you use that term.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Chris Evans
    February 26, 2016 at 3:14 pm
    If the first one has no movement, you could use the Warp Stabilizer set pretty high to eliminate it. Or you could track the motion of the second one and apply it to a null that the first is parented to so you can adjust the position manually if you need to.
  • Balazs Szabo
    February 26, 2016 at 3:59 pm
    I have 4 seperate “jump-shot” of 4 skier. The shots were made at the same location, but the cameraman was moving a few steps between shots (that’s why I need to align the shots). By mash up, I mean, that I’d like to make a single footage of the 4 people directly following each other and making the jumps.
    @Chris Evans:
    Unfortunately the first shot has also some movement, so the warp stabiliser won’t help, I’m afraid:/ (But I was looking for something like that, an fx that analyzes my footages, recognize the similarities in the background, and align them, but I guess it sounds too good to be true:D)
  • Chris Evans
    February 26, 2016 at 5:08 pm
    Warp Stabilize them both completely, but don’t crop them, just move position, scale, and rotation. Then match them up and add movement back manually (if you want the movement). Whatever you do, you’ve gonna be cutting off the edges somehow, but this way lets you adapt those edges to the needs of the moment, moment by moment.
