Activity › Forums › VEGAS Pro › Footage looks wrong.
  • Footage looks wrong.
    Posted by Martin Phillips on August 27, 2009 at 8:42 pm
    Hi there,
    pretty new to vegas, and have pro 9…. i have a shot of a moderate pan across left to right… the shot looks fine, but i have to zoom in slightly (you can just see the wind sock in the top left of the frame !!). So i have gone into ‘pan & crop’ and zoomed in just a little. On then reviewing the shot on the timeline, as the camera pans the image goes all jiggley (like its an interlacing problem)Go back into pan & crop and undo the zoom, and no problem…. i guess there is a setting somewhere i not using… the footage was shot in 1080i HDV with a Z1, and the project properties are set fine to that footage.
    I have rendered out the clip (just to check the error trasfurs to DVD – and it does).
    Any help please
    Regards
    Martin
    Martin Phillips replied 17 years, 1 month ago 3 Members · 7 Replies
  • 7 Replies
  • Stephen Mann
    August 27, 2009 at 11:44 pm
    So, where is it?
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Mike Kujbida
    August 28, 2009 at 12:02 am
    Martin, go back into Pan/Crop and raise or lower it by one line.
    What’s happening is that you’re changing the field order by being on the wrong line.
  • Martin Phillips
    August 28, 2009 at 6:07 am
    Thanks for the responce. How do I do that?
    Martin.
  • Martin Phillips
    August 28, 2009 at 6:08 am
    Steve, don’t understand?
    Martin
  • Mike Kujbida
    August 28, 2009 at 11:23 am
    In the Pan/Crop window, change the Y Center value.
    I’m not sure what value would correspond to one line so all I can suggest is changing it 0.5 units at a time, render a short segment and try it.
  • Stephen Mann
    August 28, 2009 at 4:12 pm
    When you said: “(you can just see the wind sock in the top left of the frame !!)” I thought that you wanted us to look at the problem footage.
    Steve Mann
    http://www.mmdv.com
  • Martin Phillips
    August 28, 2009 at 11:49 pm
    Ah, no – I was just explaining that that was the problem I had and the reason I was needing to crop into the shot. Regards Martin.
