Activity › Forums › Adobe After Effects › Footage looks degrade after render
Posted by Fame Little on January 17, 2007 at 4:14 amI
Fame Little replied 19 years, 8 months ago 3 Members · 6 Replies -
Majorasshole
January 17, 2007 at 5:32 amMake sure you have the comp set to full and not half. Also make sure on the time control panel that ram preview is set to full and not something else.
Fame Little
January 17, 2007 at 5:52 amThe comp is set to full and I make sure the resolution is set to full when I render but still degraded. What I don’t understand is the footage was shot 24p but it’s show fields but when I set the fields to lower the fields are gone but the footage lose quality.
Thanks Again.
Steve Roberts
January 17, 2007 at 4:10 pmVideo footage can be shot 24p, but pulldown is added in order to make it 29.97, which is a requirement of the format. Pulldown includes fields. To get it back to 24p, you need to remove pulldown. Have you checked the AE help for pulldown?
Fame Little
January 17, 2007 at 5:51 pmOnly in AE the footage looks bad after rendering, I’ve capture in FCP & Preimere Pro the footage came at the correct rate.
Fame Little
