Footage in Different Formats in Same Sequence?
I’m making a video that uses footage from two different cameras. One is a Canon T3i and I will convert the H.264 footage into ProRes 422 for editing in FCP. The other camera is a Canon Vixia HF R21, but it seems the only way to import the footage from it is to use iMovie, and iMovie only imports using Apple Intermediate Codec. So My questions are:
1. Is there some other way to get the footage directly off the camera and convert that to ProRes? I can get the footage from the T3i using EOS Utility and download the files in their original H.264 format for converting, but the Canon Vixia doesn’t open in that program.
2. If I import the footage using iMovie, and then convert the Apple Intermediate Codec files into ProRes, is the quality any worse than it would be if I was able to convert the original camera files to ProRes directly?
3. Does it even matter if I use both ProRes and Apple Intermediate Codec in the same sequence in FCP?
Thanks in advance to anyone who can give me some help!
