Activity › Forums › Apple Final Cut Pro Legacy › Footage in 16:9, Delivering 2.35.1, Editing in FCP
  • Footage in 16:9, Delivering 2.35.1, Editing in FCP
    Posted by Jesse Mendelson on August 2, 2011 at 6:47 pm
    Hello all,
    this question – or similar – has been posted before but not for a while so I’m writing to see if there is any more knowledge on the matter.
    Going to be shooting with a 5D. I believe I’m getting 16:9 footage. But this project (for the web) needs to be delivered 2.35. I’m getting the footage transcoded to pro res 422 hq and editing on quicktime.
    What i’ve seen so far is that the best thing to do is edit in 16:9 and when the cut/s are done – apply a 2:35 matte. and then either go to compressor or custom change the aspect ratio on export in FCP to get rid of the black bars?
    Does this make sense? Is this still the best method?
    Thanks in advance,
    Jesse.
    Stephen Smith replied 15 years, 2 months ago 4 Members · 4 Replies
  • David Roth weiss
    August 2, 2011 at 6:54 pm
    [jesse mendelson] “the best thing to do is edit in 16:9 and when the cut/s are done – apply a 2:35 matte. and then either go to compressor or custom change the aspect ratio on export in FCP to get rid of the black bars? “
    That’s about it… Although, you will be better off applying slugs on V2 and V3 that approximate the 2:35 matte, because these will enable you to reposition the shots on V1 on the y-axis if and when necessary.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    Don’t miss my new tutorial: Prepare for a seamless transition to FCP X and OS X Lion
    https://library.creativecow.net/weiss_roth_david/FCP-10-MAC-Lion/1
    Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
  • Stephen Smith
    August 2, 2011 at 7:29 pm
    The Widescreen Matte has a Offset slider that will move the clip up or down to better fit in the Widescreen matte.
    However, be forewarned that the FCP Widescreen 2.35 setting is 2 pixels different then compressors Panavision 2.35:1 setting.
    Stephen Smith
    Utah Video Productions
    Check out my Motion Tutorials
  • John Pale
    August 2, 2011 at 10:03 pm
    Remove the matte or slugs before exporting to Compressor. No need to render what you are going to cut off. Just use as a guide during the edit.
    This should also alleviate the problem of the small difference between Compressor and FCP.
  • Stephen Smith
    August 2, 2011 at 10:14 pm
    Keep in mind that if you remove the matte and used the Offset slider it will undo how you moved it with the Offset Slider and the Y position will return to zero.
    Stephen Smith
