Activity › Forums › Adobe After Effects › footage green/pixelated
Posted by James Kecskes on November 8, 2010 at 9:59 pmAE is doing something weird to my footage. Help.
It plays fine in the Finder or in QT, etc. But when I bring it into AE is pixelizes it and turns it weirdly green (see youtube link).
https://www.youtube.com/watch?v=vnwVTQmwILI
All I did was import the footage, drag it to the make comp icon and this is what happens. Tried restarting, all programs are up to date.
CS5, Apple 10.6.4. 8 GB 1067 MHz DDR3. 2.8 GHz Intel Core i7 iMac.
Matt Davis replied 14 years, 11 months ago 6 Members · 10 Replies -
James Kecskes
November 8, 2010 at 10:53 pmThe footage was shot with a SONY PMW-350. Codec: XDCAM HD 1080p30 (35 Mb/s VBR). Weird – we worked with this footage before and it was fine – can’t think of what changed.
James Kecskes
November 8, 2010 at 11:06 pmAnother weird example, longer
https://www.youtube.com/watch?v=l1oSqg8kfq0
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Todd Kopriva
November 9, 2010 at 5:10 amDoes this footage work in any other application? If yes, then please send a sample clip that shows the problem to aebugs -at- adobe -dot- com. Include as much detail in your bug report as possible.
If, however, this footage doesn’t play back correctly in another application, then the problem is with the footage itself.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Kylee Pena
November 9, 2010 at 2:01 pmThat’s funny, I had the same kind of footage to work with in FCP (XDCAM 35mbps) and it did the exact same thing in there when I was checking out the footage. I transcoded to ProRes and it obviously went away.
Of course, that probably doesn’t really help you much. I’ve just not seen anyone post about the footage doing the exact same weird green blocky stuff (and nobody replied to my original post about it).
James Kecskes
November 9, 2010 at 11:21 pmIf anyone else wants to test the footage and see, you can download a clip here: fileden [dot] com/files/2010/11/9/3012010//Russo2.mov
Rafael Terpins
January 19, 2011 at 11:07 amI’m having the same problem with a project that was working fine on AE 10.0.0. After the upgrade to 10.0.1.19 it messed up with the green pixelated thingy. I you try to downgrade the program this afternoon to try to save my due date. It smells like an adobe bug!
Steve Edwards
February 1, 2011 at 12:03 amI’m having exactly the same problem. Plays fine in every other application but once imported into AE does this weird green pixelation thing. Have worked around it by export it differently from FCP but not really ideal in the long term. Has anyone got a fix?
AE 10.0.1.19
Todd Kopriva
February 1, 2011 at 12:24 amSee if the solution suggested in this thread helps:
https://forums.adobe.com/message/3434600#3434600———————————————————————————————————
Matt Davis
October 7, 2011 at 3:58 pmI had the same problem.
I shoot on a Sony PMW-350w, which records in MPEG onto a flash card. Those files need to be “rewrapped” in Quicktime to be used in FinalCut Pro.
So I found on some projects that the clips I was bringing from my FCP project into After Effects had this green/pixelated effect. The wierdest thing about it was that sometimes the clips would be fine and sometimes they wouldn’t. But usually once they went green they never went back to normal. I’d even exported a project from AE that was fine, then had to make a change to something and when I went back into it, the greenage happened.
I’d found out that it had something to do with the MPEG encoding and it’s interesting to read some more of the details here now about what causes it.
My work around was instead of editing the clips in FCP in their native MPEG format, I brought them into a ProRes 422HQ timeline and then when I exported the chunks I needed to work on in After Effects they weren’t MPEG based anymore. It meant a bit more render time in FCP at the start of a project, but it got me past the green problem.
But that solution might not be for everyone.
