Activity › Forums › Adobe After Effects › Footage gets pixelated in AE?
  • Footage gets pixelated in AE?
    Posted by Tejal Shah on April 25, 2013 at 6:39 pm
    I am doing some green screen keying for a project. When I bring the footage in AE (CS6), it gets slightly pixelated towards the edges of the subject- even before I start keying. I can’t seem to figure out whats wrong with the footage. The clip I’m importing is XDCAM EX 1080p30 (35Mb/s VBR).
    I’m dragging it right to the comp, so the comp settings are the same. Please let me know if there is any solution. Thank you!
    John Cuevas replied 13 years, 4 months ago 3 Members · 3 Replies
  • Tejal Shah
    April 25, 2013 at 7:19 pm
    Thank you for responding! It may be interlaced. How do I interpreted the footage properly?
  • Walter Soyka
    April 25, 2013 at 7:26 pm
    XDCAM footage can be anamorphic, with pixels wider than they are tall. Your footage may be 1440×1080 with a pixel aspect ratio of 1.33.
    If this is the case, the footage may look a little jagged in your comp viewer. You have two options:
    Toggle the Pixel Aspect Ratio Correction button under the viewer (it’s a rectangle with a bi-directional arrow above it) to see your image as square (squished-looking) pixels.
    OR
    After Effects > Preferences > Previews, then change the Viewer Quality > Zoom Quality away from “Faster” to either “More Accurate” or “More Accurate Except RAM Preview.”
    Walter Soyka
  • John Cuevas
    April 25, 2013 at 7:27 pm
    Right click it in the project window and choose interpret footage.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
