Activity Forums Apple Final Cut Pro Legacy footage from dvd into a ftp folder
  • footage from dvd into a ftp folder
    Posted by David Linstrom on May 7, 2008 at 8:15 pm
    Greetings
    a client is requesting footage asap. He suggested that I load samples from shows I’ve shot into his ftp folder. Everything I have is on dvd. Any idea how I can do this?
    Many thanks
    Dave Linstrom
    LA based DP
    Mike Procunier replied 18 years, 4 months ago 4 Members · 5 Replies
  • Thomas Mcnamara
    May 7, 2008 at 8:19 pm
    MPEG Streamclip -> FCP -> Compressor -> Cyberduck
  • Jeff Carpenter
    May 7, 2008 at 8:31 pm
    David,
    Do they need to edit the footage, or just view it? Big difference.
    If they only need to see it then just use Handbrake to create a 320×240 H.264 file directly from the DVD. Then just upload that.
    Standard disclaimer: Only use Handbrake for video you have the right to transcode from DVDs.
  • Mike Procunier
    May 7, 2008 at 10:28 pm
    I’ve had good luck with MacTheRipper to rip DVDs.
  • Thomas Mcnamara
    May 7, 2008 at 10:36 pm
    AFAIK, MTR will only rip the vob files…still would need another program to generate quicktimes if he wants to upload to an ftp server, especially at more manageable file sizes.
    I second the handbrake suggestion; if watching is all that matters, and you don’t really need in/out control over the clips, skip some steps and just rip to a h264 right there.
  • Mike Procunier
    May 7, 2008 at 10:59 pm
    Thanks, I’m going to download Handbrake and give it a try…
