Activity Forums Apple Final Cut Pro Legacy footage falling out of sync
  • footage falling out of sync
    Posted by Aaron Smith on August 4, 2010 at 4:17 am
    I’m editing a music video that was shot on 16mm.
    the song was taken from the cd that was used as playback during the shoot, which she then of course, sang along with.
    after telecine, the footage came to me as a quicktime uncompressed 10 bit 4:2:2. frame size 720×486 and 29.97fps
    as i try and sync up my footage to the song, it starts falling out of sync as the song goes along. the footage ends up moving faster than the song actually is.
    not sure what i should do…is this a pulldown issue?
    i tried slowing the footage down a couple percent, but that doesn’t seem to do the trick. thanks in advance for the help…i hope it’s something simple I am overlooking.
    aaron
    Chris Todd replied 16 years, 1 month ago 2 Members · 1 Reply
  • Chris Todd
    August 4, 2010 at 10:27 pm
    This is an interesting issue. I had a weird version of it yesterday. I had recorded HD video at 23.98fps with accompanying 48kHz audio from the camera mic. I also recorded audio separately at 48kHz. (.WAV) The two should sync up perfectly, right? Well I bring both versions of the sound into an FCP timeline and the sync drifts out.
    OK so bring the same elements into (trusted) ProTools and hey presto the two versions of the sound sync up perfectly!
    Wot is the haps?
    Check the sample rate stamp on both versions and they both tell me 48kHz.
    Hmm… If I export the separate audio from protools with sample rate conversion to 48.048 (0.1% pull up) and import that into FCP, It synchronizes in the timeline. (I did a quick QT export and the output stays in sync too!)
    What does this tell me? If the video is running at camera speed 23.98fps then any sync sound running at capture sample rate should be exactly in sync. It IS in PT; it ISN’T in FCP. Therefore it would seem logical that FCP is running an automatic pull up on the QT picture/audio file OR is applying a pull down to the separate .WAV audio file. Either way my brain is now on fire… but after my SRC on the .WAV material I can now proceed… It’s not ideal.
    If anyone can shed further light on this I’d be grateful.
    CTPP
