Activity Forums Apple Final Cut Pro Legacy Footage Direct to DVD
  • Footage Direct to DVD
    Posted by Phil Schmidt on February 26, 2008 at 2:47 pm
    What is the best option for burning DV footage direct to a DVD for later use?
    Basically I want to take my footage I have shot and burn it into a format that I can archive on a DVD to import into FC for later use but not capture direct to my hard drive then burn.
    Is there a real-time burn to DVD option?
    Phil
    Walter Biscardi replied 18 years, 6 months ago 2 Members · 1 Reply
  • Walter Biscardi
    February 26, 2008 at 2:59 pm
    [Phil Schmidt] “What is the best option for burning DV footage direct to a DVD for later use?”
    Capture first, then burn to DVD the quicktime files.
    If you record directly to DVD, such as through a DVD Recorder, you’re going to compress everything to MPEG-2 format. That will take your 5:1 compressed DV format and make it about 25:1 compressed MPEG-2. In other words, making your DV quality drop by a LOT.
    If you want to avoid capturing, switch to a hard drive acquistion on the camera such as P2, FireStore, XDCAM, etc….
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR
    The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
