Activity › Forums › Apple Final Cut Pro Legacy › Footage Depth
Footage Depth
Posted by Anthony Winson on November 30, 2009 at 11:42 pmNot sure if anyone has already put up post on this but I’m new to the site and would really appreciate it if anyone could talk me through a tutorial for creating depth in my footage I.E blurring background but keeping the actors in focus. I only have final cut pro on my mac.
Many Thanks In advance
AnthonyRafael Amador replied 16 years, 9 months ago 5 Members · 5 Replies -
Shane Ross
December 1, 2009 at 12:07 amWell, you can blur, but it won’t really add depth. It’ll be fake, and might look fake. The only way to really do this is shoot with a camera that has a good lens that does this. You can try to layer your footage, and put an 8-point garbage matte around your subject. Then you will be in keyframe heck as you adjust every frame to make sure that the matte stays around your subject.
The bottom layer you can add the DEFOCUS plugin (built in), or if your graphics card can’t deal with that, then Gaussian Blur. Still, might look odd.
Shane
Read my blog, Little Frog in High Def -
Colin Mcquillan
December 1, 2009 at 12:15 amLike Shane said, best done in camera with a good lens and a camera with 2/3’s inch chips.
However, you can achieve adequate and/or interesting stylized results with masks (multiple masks, each with a different strength of blur to add depth and distance) I would not think of doing this in FCP though. You would need to send the footage to After Effects or Motion to get acceptable results.
Colin McQuillan
Vancouver, B.C. -
David Roth weiss
December 1, 2009 at 12:19 amAs both Shane and Colin mentioned, FCP is not the ideal tool for the job, because it really requires rotoscoping and tracking to be done properly. So, that being said, doing a convincing job using only FCP is not terribly easy. However, if you are patient, you can do a reasonable job by using the techniques both of the other guys mentioned.
See the tutorial below for a bit of help with the garbage mattes in FCP:
https://www.kenstone.net/fcp_homepage/basic_matte_filters.html
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
Anthony Winson
December 1, 2009 at 8:11 amThank you to everyone who comment its been very helpful info very much appreciated.
Anthony
sinworks pictures
Rafael Amador
December 1, 2009 at 5:35 pmHi Anthony,
As Shane, Coling and Dave point, a simple lineal blur or the backgroung would get very little natural.
In the reallity ceratin areas will be more out of focus than others.
You can get that with gradients.
In FC you can use any Plugin that makes “Z Defocus” “Z Blur” or similar. I have it with the Sapphire
Ae have something similar, and SHAKE too.
This woks basically making a mask with different levels of gray. In the blacks you will have full defocus, and in the white will stay in focus, with the in-between levels set by the grays.If the camera doesn’t move, is easy to do.
If its moves, will depends.
However you do it is something very interesting to kno the technique.
Cheers,
rafael
