Activity › Forums › Adobe Premiere Pro › Footage darkened when imported to premiere
Posted by Kylie Laston on October 22, 2010 at 4:37 pmI imported some 35mm footage to premiere, in premiere it looks
much darker.. when I look at the footage in quick time before the
import it looks brighter, more vibrant and accurate to what I was
seeing at the color correction lab.Anyone know why this is happening and how to correct it?
My quality settings are set to high. It is imported in
HD with the intention of being transfered to XDCAMKylie Laston replied 15 years, 11 months ago 4 Members · 7 Replies -
Vince Becquiot
October 22, 2010 at 5:09 pmKylie,
What format was the original footage encoded with and what color space?
Vince Becquiot
Kaptis Studios
San Francisco – Bay Area -
Kylie Laston
October 22, 2010 at 5:39 pmdnxhd 175 was the codec and then… rec709 was the color space.
Vince Becquiot
October 22, 2010 at 6:04 pmIs it possible that you are seeing a gamma shift introduce by an FCP / Quiktime export?
I would also try a quick sample export from After Effects using a 709 comp to Quicktime Animation to see if the problem is still there afterwards.
Vince Becquiot
Kaptis Studios
Kevin Monahan
October 22, 2010 at 6:09 pmAlthough this page is for After Effects, you can read about color management issues (including external links) here: https://bit.ly/9cPbUM
Kevin Monahan
Sr. Content and Community Lead
Adobe After Effects
Adobe Premiere Pro
Adobe Systems, Inc.
Follow Me on Twitter! -
Kylie Laston
October 22, 2010 at 6:14 pmI directed the film so I’m not the most technically savy, I don’t own a copy of After Effects.. this doesn’t have to do with the way it looks exported. I’m saying in adobe while I’m editing it looks darken when imported not exported. but when exported it does maintain the darkened look… also interestingly enough, before the video is rendered it displays its original colors.
Tim Kolb
October 23, 2010 at 6:00 pmQuicktime is typically the culprit. Quicktime gamma errors just seem like they’ll be around until QTX is completely implemented (hopefully QTX has this problem solved…) and QT7 and earlier are banished forever…
Are you watching the footage on the same monitor in each case?
…and are you Windows or Mac?
TimK,
Director, Consultant
Kolb Productions, -
Kylie Laston
October 24, 2010 at 12:36 amYes same monitor in each case.. the quick time displays it more
accurately to how I saw it originally at the color correction labs.
