Activity Forums Apple Final Cut Pro Legacy Footage Count burn-in
  • David Bogie
    October 3, 2006 at 7:44 pm
    Feet and frames might be possible but where would the reference signal come from? Is there keycode or edge code available on a track or is it to be arbitrary?
    bogiesan
  • Steven Gonzales
    October 3, 2006 at 7:53 pm
    If you want a foot and frames count, you can nest the sequence and add the timecode generator filter, then set the format to 16mm or 35mm.
