Activity › Forums › Apple Final Cut Pro Legacy › footage captured out of sync
  • footage captured out of sync
    Posted by Julie Espinosa on January 23, 2008 at 5:31 pm
    maybe someone out there can shed some light on this problem.
    we are capturing DV footage that has been shot on an HVX200. in the viewer the footage is in sync, but when it is captured (with or without advanced pulldown removal) and replayed it is out of sync. when i use capture now, it appears to be in sync while capturing, but then is not in sync once it is captured
    we think that it may be due to the fact that we have a firewire setup that somehow cannot compensate for an error that occurred while recording. we have hundreds of tapes and this is the only one to have this error.
    anyone have any ideas? i’m thinking that i’m going to have to create a new master and see if that works, but i wanted to check here first.
    thanks!!
    Andrew Commiskey replied 18 years, 8 months ago 3 Members · 2 Replies
  • Paul Escandon
    January 23, 2008 at 8:22 pm
    Hmm… you might try setting the device setting to non controllable device and hit play on the camera to capture the whole tape. Since you say it may be a recording error and it’s only happening on one tape, there’s a chance this will work. There is also a chance that it might not be completely accurate timecode on the file if there were some dropouts… but if you can live with that it’s worth a shot.
    Paul Escandon – Lead Editor @ Outdoor Channel
    Producer | Director – Oremus Productions
    http://www.oremusproductions.com
    Apple Certified Trainer – Final Cut Pro
    Adjunct Professor of Media – JPCU
    MacPro Quad-core XEON
    8Gb ram, ATI Radeon X1900 XT, 2TB internal RAID
    2 20″ Dell UltraSharps + Matrox MXO & 23″ ACD
  • Andrew Commiskey
    January 24, 2008 at 8:20 am
    I ran across a problem with a Panasonic deck where we captured through firewire, Using Capture Now, and let it roll to the end of the tape (where it would usually give you the “End of Tape” warning) all the clips that were captured at the end of the tape had the audio frequency set at 47.51 (find under EDIT – Item Properties). This audio slowdown had a field day with the audio sync. The only fix was to recapture with an out before the end of the shot part of the tape. This applies to batch capture and Capture Now. You have to hit escape before it goes black. I have only found this on 1 Panasonic deck using firewire. Sonys are fine. Anyone else have this problem?
    Best,
    Drew
    Chaos is the beginning of everything.
