Activity Forums Adobe After Effects Footage ‘bouncing’ upon render.
  • Footage ‘bouncing’ upon render.
    Posted by John Davies on April 22, 2010 at 11:03 pm
    In AE CS4 I have a 3D environment containing vector art and footage.
    In a RAM Preview the composition plays fine with smooth running footage. Once rendering, however, I can see the clips ‘bouncing’ slightly every 5 frames or so. The graphics all stay as they should.
    The imported footage has been scaled very slightly and has no effects added but a couple of masks.
    Here is an FLV sample:
    https://www.callumations.com/bits/MW_Bounce.zip
    This problem occurs no matter which format I decide to render.
    Tudor “ted” jelescu replied 16 years, 4 months ago 2 Members · 1 Reply
  • Tudor “ted” jelescu
    April 23, 2010 at 6:35 am
    If your source footage is interlaced ( it looks like DV to me) then make sure you interpret the footage in the project panel – de-interlace ( Fields and Pulldown > Separate fields > Lower field first for DV) and check the Preserve edges.
    Tudor “Ted” Jelescu
    Senior VFX Artist
    Bucharest, Romania
    http://www.ennstudio.ro
