Activity Forums Adobe After Effects Footage becomes noisy in AE?
  • Footage becomes noisy in AE?
    Posted by Sven De bruyne on April 14, 2010 at 8:26 am
    Hi guys,
    I shot a bunch of nicely lit greenscreen footage the other day, it’s shot using the JVC-HM100E in MOV format (with XDCAM EX). When I look at the footage in preview or quicktime or final cut, the colors stay nice and even (as they were recorded).
    As soon as I import the footage in After Effects (CS4) however it becomes slightly darker, more saturated and noisier and becomes almost impossible to key nicely! I tried turning on the ‘match legacy after effects quicktime gamma adjustments’ but no luck. I tried exporting the footage to a TIFF sequence from Final Cut, but the same problem when I import it…
    I’m running out of ideas here! Someone please help!
    Sven
    Richard Ducasse replied 16 years ago 3 Members · 7 Replies
  • 7 Replies
  • Erik Waluska
    April 14, 2010 at 5:25 pm
    Sounds like a color management problem. Do you have color management turned on? If so, try turning it off or changing the setting to match your other apps.
    -E
  • Sven De bruyne
    April 14, 2010 at 6:02 pm
    I don’t have color management turned on. Working space is set to ‘none’. Should I set it to something different here?
  • Sven De bruyne
    April 14, 2010 at 6:05 pm
    Maybe an important fact: when I add a levels-adjustment to the footage, the histogram is already tampered with (you know, when there’s ‘lines’ in your graph showing missing values)… How the hell can this happen?
  • Erik Waluska
    April 14, 2010 at 7:19 pm
    That’s very strange. I’m afraid I don’t know what to tell you. Hopefully, someone else will be able to help. Sorry. Good luck.
    -E
  • Sven De bruyne
    April 14, 2010 at 8:06 pm
    Wow, this was kind of my last resort. Hope someone else out here knows what the problem could be?!
  • Erik Waluska
    April 14, 2010 at 8:52 pm
    You might want to post in the JVC Cameras and Sony XD Cam forums as well.
  • Richard Ducasse
    September 6, 2010 at 4:14 pm
    I am having the exact same problem. Got some HDCAM EX clips, was not supposed to be green screen, but client shot some at the last minute. Can’t get a clean key with Keylight. Looks OK until you look close. Very grainy and noisy at 100%.
    Tried using After Effects Color Difference key, and it’s less noisy, but not as good of a key as Keylight.
    Did anyone ever come up with a solution to get rid of the noise in green screen keys with HDCAM EX?
    Any info would be most appreciated.
