Activity › Forums › Maxon Cinema 4D › Fonts not showing up
Posted by Mitch Hardison on June 25, 2010 at 7:55 pmWhy aren’t all my fonts showing up in cinema 4d?
Brian Jones replied 10 years, 2 months ago 3 Members · 8 Replies -
Mitch Hardison
June 26, 2010 at 1:22 amjust some of them. I know I can’t turn some fonts into 3d text but I am missing a lot of them that are in my font folder
Brian Jones
June 26, 2010 at 1:48 am10.5 can’t use a lot of fonts. 11.5 does much better and will work with many of the fonts that did not work in 10.5. Some fonts still won’t work though, particularly 3rd party free fonts. If you really want a font and have Illustrator (or some vector program) that will open the font you can always save the font as splines and import.
Mitch Hardison
June 26, 2010 at 3:34 amAwesome. I have illustrator but don’t know much about it. How do I save it as splines? Thanks a lot for the help
Brian Jones
June 26, 2010 at 4:16 am•just create the text you want in Illustrator
– size does not matter much (but it does make a difference), you can scale it when it gets into C4D
– C4D will use Illustrator’s origin (bottom-left) as the origin of the text when you import it so you probably want to put the text in the lower left corner before you save.
•with the text selected choose Type/Create Outlines – this is the bit that turns the text into splines
•then save it to an Illustrator 8 file
– save to an Illustrator file but in the second save dialog “Illustrator Options” choose Illustrator 8 for the Version
•Open (or Merge) into C4D -
Kimi Svetec
June 4, 2016 at 9:05 amhi, i have a problem. my fonts in cinema 4d doesn’t open.
any of them. when i click on fonts nothing happens.
can you help me please? -
Brian Jones
June 4, 2016 at 4:02 pmi haven’t heard of no font’s at all showing up, only just some of them. But you haven’t described much, what system are you on? What version of C4D? Where is this “Font’s” button (in what object)?
