Activity Forums Adobe After Effects fonts not dispaying properly when using numbers plugin
  • John Cuevas
    October 13, 2012 at 12:28 pm
    Are the numbers moving around a bit from number to number? That’s due to the proportional spacing that is created in almost all effects. One thing you can try is unchecking the proportional spacing check box.
    To really correct the bouncing numbers result, you need to use a mono-spaced font.
    Here’s a link to popular monospaced fonts.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
