Activity Forums VEGAS Pro Font too big?
  • Graham Bernard
    January 17, 2011 at 7:46 pm
    From the sample you have posted I don’t understand your problem. You’ve posted a still relating to the chequer board, no text.
    Grazie
  • Cassie Ross
    January 17, 2011 at 8:02 pm
    Oh, my apologies. I’m trying to show that the video effects and media generators are not showing the entire content of their properties.
  • Mike Kujbida
    January 17, 2011 at 8:09 pm
    You’re not seeing what you need to see because of the way Pro 10 now does things.
    Click the “Animate” button and you’ll see the keyframe timeline.
  • Cassie Ross
    January 17, 2011 at 8:24 pm
    When I click animate the timeline shows up. But the right side of the screen is still cut off.
  • Graham Bernard
    January 17, 2011 at 11:09 pm
    This looks like a mashed up install of Vegas or an earlier build of Vegas Pro10. What version and build of VP10 are you using? Try a Factory Reset?
  • John Rofrano
    January 18, 2011 at 2:31 am
    Have you changed the DPI of your Windows fonts to something larger than the default? If you change your Windows font size it will mess up a lot of applications. In general, don’t do that.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
