Activity › Forums › Apple Final Cut Pro Legacy › Font size
Font size
Posted by Andrea Mino on November 18, 2008 at 5:15 pmhi all,
is there a way of changing the font size of several clips at once instead of going one by one?
thanks
Troy Lanier replied 15 years, 1 month ago 5 Members · 6 Replies -
Alan Smith
November 18, 2008 at 8:02 pmhighlight the clip with the settings you want to add to others, control-click or right-mouse clip, copy. Highlight all the clips you want the attributes added to and control click or right-mouse click, paste attributes. Select the attributes from the list.
Alan
Alan Smith
Media317Check out my blog – https://media317.com
Alan Smith
November 19, 2008 at 4:39 pmSorry. . . No attributes that can be changed for font size. Looks like you would have to change each individual clip.
Alan
Alan Smith
Andrea Mino
November 19, 2008 at 11:19 pmyeah, i was just wondering what attributes to select cause i’ve had tried them all and neither font nor color font changed. That sucks.
thanks anyway.
Tony Varin
December 8, 2008 at 7:10 pm(I know it’s been awhile since last post…oh well)
The best thing to do at this point, if possible for you, is to use scale if other basic motion isn’t affected and add a color changing filter like color correction. Then paste attributes will work. Not the best way, but fast and efficient.
Tony
Troy Lanier
July 28, 2011 at 12:55 amI exported XML, used a text editor “text wrangler”, used find and replace every instance of this code
fontsize Size
0
1000
24 with this code
fontsize Size
0
1000
36 it changes font size from 24 to 36
i did the same thing for font color, font style (bold), and font.
It worked for over 500 titles I had to change, and saved me tons of time and wrist wear.
I lost all render files though from other renders.
