Activity › Forums › Adobe After Effects Expressions › font size scaling up or down automatically whan adding more character to bounding box
  • font size scaling up or down automatically whan adding more character to bounding box
    Posted by Adi Arusi on August 13, 2016 at 8:05 am
    hi all
    I have AE templaet with a text bounding box, The text changes every day
    the problem start when i have a lot of character and the text is cropped out of bounding box aria
    today i manualy change the font size and the line spacing every day
    I wonder if there’s a expression or script thet make the text, the character tracking and the line spacing resize and fit to the bounding box automatically No matter how many characther i have
    thanks all
    John Herrera replied 9 years, 11 months ago 3 Members · 6 Replies
  • Kalleheikki Kannisto
    August 13, 2016 at 1:06 pm
    See here:
    https://forums.creativecow.net/thread/227/33411
    Senior Graphic Designer
  • Adi Arusi
    August 13, 2016 at 4:45 pm
    Kalle Kannisto you are aaaawesome
    This is exactly what I need…
    thank you very much
    Adi
  • Adi Arusi
    August 16, 2016 at 12:11 pm
    thank’s Kalle about your help
    i have one more question
    when i try to center the text it jumps to the right side and dosent stay in the react solid
    if i scale down the text box and make it centerd the next inserted text will be small
    how can i make the text centered whit this expression?
    thanks
    adi
    August 17, 2016 at 3:49 pm
    Hi Adi, you’ll have to center the anchor points at the top of both the text and the rectangle and remove the x offset by margin amount from the text position expression.
    10425_fittexttotextboxcentered.aep.zip
  • Adi Arusi
    August 18, 2016 at 8:34 am
    thank you very much Kalle
  • John Herrera
    October 29, 2016 at 12:11 am
    Kalle,
    This is very helpful! Thank You!
    I see the two examples for both Left alignment to the bounding box and Center alignment to the bounding box, both of them work for me as i would expect.
    What I’m trying to do here is now get Right alignment to the bounding box, but regardless of what i do i cannot get it to work.
    What should i be modifying here? The position expression? The Anchor point of the text? Some combination of the two?
    Any feedback would be very helpful, thanks for the excellent pointers already!!
    -John Herrera
