Activity Forums Apple Final Cut Pro Legacy font probs in FCP
  • font probs in FCP
    Posted by Mrclean796 on August 30, 2005 at 9:28 pm
    I have been trying to get a font to work with FCP but it just will not allow me to use it for some reason. I loaded the font with Fontbook, and that should be picked up in FCP but is isn’t showing up in the options for a usable font when I try to use the text tool. It wont even let me use it in Boris if I try to use Text3D to do text. I am supposed to be using Futura Condensed Medium, or Futura Condensed (neither seems to work).
    Hawaiirap replied 21 years ago 4 Members · 3 Replies
  • Sean Lander
    August 30, 2005 at 10:11 pm
    What kind of Font files are they? PC MAC are they TrueType or Bitmapped?
  • Gary Adcock
    August 30, 2005 at 10:16 pm
    [MrClean796] ” have been trying to get a font to work with FCP but it just will not allow me to use it for some reason. I loaded the font with Fontbook, and that should be picked up in FCP but is isn’t showing up in the options for a usable font when I try to use the text tool.”
    Sorry no postscript fonts in FCP,
    only Truetype, Open Type and Bitmap fonts work in FCP.
    IF you really need the font work in After Effects which does not have the restriction.
    gary adcock
    Studio37
    HD and Film Consultation
  • Hawaiirap
    September 2, 2005 at 7:45 am
    Adding to the font problem..after upgrading to FCP HD 5.0.2 and OsX 10.4.2 previously used fonts within fcp are not keying well and the sizes have changed. eg. optima original and the “new” optima are not the same.. got any ideas? I was using the basic text which was working just fine prior to the upgrades. Unfortunately, the OS and FCP upgrade were done at the same time so I’m not sure where to chase the problem. Any direction would be appreciated.
    regards,
    bob
