Activity › Forums › Apple Final Cut Pro Legacy › Font Install in Final Cut Pro
Mark Maness
August 31, 2007 at 2:25 pmI found that its better to use Font Book to install fonts. I haven’t had any issues since doing this.
_______________________________
Wayne Carey
Schazam Productions
http://www.schazamproductions.com
https://blogs.creativecow.net/waynecarey -
Joe Murray
September 1, 2007 at 12:04 amI have had this problem as well, going back several versions of FCP. It’s one of those things that just never gets fixed. I usually just end up creating the graphic in Photoshop and importing it.
Dani_starr
September 1, 2007 at 12:15 amDarn it! I was afraid someone might say that.
After trying everything that everyone has mentioned – that one particular font still is not showing up in FCP. I’ll have to do the photoshop thing.
Thanks for the help!
Steve Hirsch
September 1, 2007 at 9:43 pmI believe the issue is the kind of font. FCP only uses TrueType fonts. If I have a project that requires lots of title cards, and I need to edit them on the fly using a particular typeface, I convert them to TrueType using Fontlab’s TransType Pro. Then I install that font using fontbook and all is well in FCP.
Steve
Steve Hirsch
September 1, 2007 at 9:47 pmOpps. I just realize that in your original post you specified that it was a TTF. I’m guessing that’s short for True Type Font? So I guess I’m no help. 🙂
Chris Deroche
May 22, 2008 at 2:38 pmSo first of all, I hope you have upgraded to 6.0.3 since you posted this. That won’t fix it but it will help the rest of your program.
Font Book is the key. Open it up and see if the desired font is grayed out with an “Off” next to it. Right-click and click “Enable font”. This worked for me when I had the same problem.
Hope it helps.
Troy Lanier
January 26, 2012 at 6:41 pmIts 2012. I used font installer. I rebooted. No go.
And then this worked for me.
https://alex4d.wordpress.com/2008/10/08/final-cut-pro-free-plugins-to-make-all-fonts-available
Thomas leonardo Pedersen
December 10, 2013 at 10:45 pmFont Book is the solution.
Drag and drop your fonts to Font Book (search for it, if you don´t know where to find it)Right click on the fonts (after pasted into the library) and Validate Font.
Restart FCP and it should be solved.
Just did the same, after having the same problem.Best luck.
