Activity › Forums › Adobe After Effects Expressions › follow with inertia
follow with inertia
Posted by Laura Dominguez on September 14, 2007 at 8:20 amHi,
How can I make an object follow another object position but with some inertia or delay effect?Thank you!
Gil Rokplo replied 19 years ago 3 Members · 3 Replies -
Gil Rokplo
September 14, 2007 at 2:10 pmyou may use the ValueAtTime , and link the position of object 1 to position of object2 at time+ n frames
Mike Clasby
September 14, 2007 at 4:09 pmHow about this:
Elastic Connection
https://www.motionscript.com/design-guide/elastic.html
Play with the Dampening (damp) and Rest Length (restLength).
Gil Rokplo
September 15, 2007 at 6:54 pmDo you think this expression could be adapted to make a kind of “spring inertia” to the rotation of a layer ?
What i’d like to do is to automaticaly make a layer rotate when the layer moves (as if the acceleration makes it turn) and when it stops, the layer turns back to its position, but further than the initial position because of the inertia, then back again etc … untill it finally stops turning.
this could be hepful to bring some elasticity to character animation
Thanx !
