Activity Forums Adobe After Effects Follow the Leader Expression–Only on one axis
  • Follow the Leader Expression–Only on one axis
    Posted by Thomas Downs on September 18, 2006 at 4:03 pm
    This well-known expression makes a layer ‘follow the leader.’ It works on both X and Y. How do I restrict it to only the X dimension?
    delay = 5; //number of frames to delay
    d = delay*thisComp.frameDuration*(index – 1);
    thisComp.layer(1).position.valueAtTime(time – d)
    Cheers!
    Dave O’dowd replied 19 years, 9 months ago 5 Members · 5 Replies
  • Mylenium
    September 18, 2006 at 4:35 pm
    You simply extract it by accessing the array it is stored in 😉
    thisComp.layer(1).position.valueAtTime(time – d)[0]
    Mylenium
    [Pour Myl
  • Richard Powell
    September 18, 2006 at 5:20 pm
    Hey Mylenium, that was me (govinda) using an old account out of desperation.
    That line of code gives me an error when I replace my second line with it. ‘Expression result must be of dimension 2, not 1. Error occurred at line 0.’
    Is there more to this?
  • Dan Ebberts
    September 18, 2006 at 5:26 pm
    This should do it:
    p = thisComp.layer(1).position.valueAtTime(time – d);
    [p[0],value[1]]
    Dan
  • Mylenium
    September 18, 2006 at 6:47 pm
    Yeah, sorry for being so ominous. Dan has already provided the full code, so go, get it. ;O)
    Mylenium
    [Pour Myl
  • Dave O’dowd
    November 9, 2006 at 4:59 pm
    Hey all,
    I’m trying to use this expression to create a herd of caribou following a leader along the x-axis of my comp, but when I apply the expression I get the error “no property or method named delay”, any suggestions?
