Activity Forums Adobe After Effects Expressions Follow a motion path in 3D space
  • Follow a motion path in 3D space
    Posted by Julie Bigford on September 28, 2005 at 10:27 pm
    I have several photos all parented to a long frame. I want this frame to “snake” or move like a train (each photo is an individual car) through the screen from right to left while moving on the z-axis. I’ve tried animating a null object on the path that I want, then parenting the frame to it. However, with this, the frame as a whole unit moves along the path, rather than a train snaking through the screen.
    I’ve also tried making a path with the pen tool on a solid layer, then copying the mask to the “position” property of the frame, but this doesn’t work in 3D space.
    Any ideas?
    Thanks in advance!
    Julie
    Julie Bigford replied 20 years, 11 months ago 3 Members · 6 Replies
  • Steve Roberts
    September 29, 2005 at 4:23 pm
    Did you try layer>transform>auto-orient, then orient along path?
    Steve
  • Steve Roberts
    September 29, 2005 at 4:25 pm
    Indeed. AE is quite limited in a 3D sense.
  • Julie Bigford
    September 29, 2005 at 5:26 pm
    Yes, Steve. I tried “orient to path”, but it didn’t achieve the desired effect.
    Thank you both for your help. I was afraid the answer was “it can’t be done” but there’s a lot I still don’t know about the program and it never hurts to ask.
    Julie
  • Ken Latman
    September 30, 2005 at 3:44 pm
    I kinda built this in one of my projects.
    I first build a layer with my path and then rotated in 3D space 90 degrees so it stayed flat.
    Then I parented a null object to that path so it was perpendicular to the path in 3D.
    Next add a new camera and have the point of interest set to somewhere on the null.
    What I essentially did was have the camera along the path to look everything else was moving.
    I set many lights above my path so I could get the right look.
    There was alot of adjusting but you need to work with multiple views of your comp open.
    Hope this helps somewhat.
  • Ken Latman
    September 30, 2005 at 3:48 pm
    I just rechecked my old project to see how I did it.
    Let me correct one thing. After I made my path and rotated it, I copied the mask/path and pasted the points as positions in my Null object.
    The one drawback is you can not adjust your position like you would a draw on path effect would.
    Perhaps you can use an expression to link your position keyframes to your points on the path.
  • Julie Bigford
    September 30, 2005 at 5:57 pm
    Thanks Ken! I’ll give this a try sometime (I’ve already had to come up with an alternative for the current animation). I appreciate the advice!
    Julie
