Activity › Forums › Apple OS X › folder won’t open
  • folder won’t open
    Posted by Peter Ralph on June 30, 2006 at 11:12 pm
    10.3.9 – g5
    an intermittent problem where certain folders won’t open. I can expand the folder in the sidebar and all the files are accessible but if I double click then the folder window pops up empty for a second and then closes and a completely different window shows up. Then the problem goes away after a day or two – a couple of weeks later it happens with another folder. Any ideas?
    George replied 20 years, 2 months ago 3 Members · 5 Replies
  • Simon Carlson-thies
    July 1, 2006 at 5:38 am
    Verify your disk…
    Are you running anyother applications when it happens…?
    When did it start?
    What’s in the folder…?
    Simon Carlson-Thies,
    Digital Light Graphics And Animation
  • Peter Ralph
    July 1, 2006 at 6:00 am
    the problem was .m2v files created by compressor 1 in 10.3.5. – (I cant get compressor 2 in 10.3.9 to behave) – for some reason these files wont even show the getinfo, but work fine in DVDSP.
    The weird part – the folders open fine when the window is small so the problem only appears when the window is around half screen or more
    July 1, 2006 at 3:36 pm
    It sounds to me like a corrupt set of files in the folder or the folder may be corrupt… I would boot off the install disc and verify your disc make sure there is no data corruption…
  • Peter Ralph
    July 3, 2006 at 8:27 pm
    its the m2vs for sure everything else checks out fine.
    thanks for the response
  • George
    July 5, 2006 at 6:31 pm
    I’ve got a similar problem with M2V files in general. For some reason, the OS doesn’t seem to like them. Anytime I try to rename them, or get info, the finder window crashes and I have to relaunch. Very frustrating. This is on OSX v 10.3.9
