Activity › Forums › Maxon Cinema 4D › Fog problem – Mist on horizon disturbs background image.
  • Fog problem – Mist on horizon disturbs background image.
    Posted by Per Sverre wold-hansen on May 9, 2013 at 12:05 pm
    See image enclosed. Open sea landscape. Floor is ocean.
    Made a huge diameter, low vertical, open cylinder. No caps. Added a transparency with vertical gradient (and a white color) to function as distant fog/mist.
    However, strange things happen to the background image. The color of the sky background is “disturbed”. The top end of the cylinder is – sort of – visible…
    Same thing happens when applying a “fog texture” to the cylinder.
    What gives?
    PerS
    Per Sverre wold-hansen replied 13 years, 4 months ago 2 Members · 4 Replies
  • Per Sverre wold-hansen
    May 9, 2013 at 12:07 pm
    PerS
    May 9, 2013 at 12:11 pm
    Sorry – Not fog, but “Alpha”
    PerS
  • Ashish Gupta
    May 11, 2013 at 11:11 am
    Per Sverre Wold-Hansen,
    Maybe have a look at using the Fog shader .
    Here’s an example file :
    5988_fog.c4d.zip
    Ashish Gupta
    Motiongraphics artist and 3d generalist
    aashi.29nov@gmail.com
    May 11, 2013 at 1:27 pm
    Thanks for the effort, but I do not get what I want THAT way either…
    When the torus is expanded to “horizon” and adjusted for heighth the same problem occurs.
    Here are a couple of examples – fixed in Photoshop – which show more-or-less what I hope to achieve in animations in C4D…
    Other ideas?
    PerS
