Activity › Forums › Adobe After Effects › Fog in Z depth.
  • Fog in Z depth.
    Posted by Bas V breugel on May 20, 2015 at 2:39 pm
    Hi guys,
    I would like to create a look as following;
    The scene is made up in 2,5D, there are seperate illustrator objects in z space. A man, some trees, a skyline etc. wenn you move the camera sideways you get that nice parallax effect between the objects.
    Now i would like to dolly backwards with the camera and lets the objects fade away in Z depth. a sort of fog kinda speak. I could do it manualy by fading the opacity of each layer but that would be unconvienent with keyframing and timing re-adjustments. The built in after Effects camera has the ability depth of field but that only makes objects out of focus wenn they get in futher in z space.
    Im trying out Element 3D but the fog ability only works on the elements inside the element (3d obj) not the other layers in my comp. (As far as I could find out)
    Jim Scott replied 11 years, 4 months ago 4 Members · 3 Replies
