Activity Forums Maxon Cinema 4D Fog in Camera Map
  • Fog in Camera Map
    Posted by Edgard Iriarte on April 29, 2008 at 2:54 pm
    Hi folks, i have a a few objects with camera map projection. One of the geometries have an alpha channel, but this alpha channel is fine when i dont have fog in my scene, as soon as i activate the fog it shows part of the alpha channel of my geometry.
    Anybody has encounter the same problem?
    Adam Trachtenberg replied 18 years, 4 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    April 29, 2008 at 10:55 pm
    Yes, unfortunately it’s a limitation with Cinema’s fog. What you might do if you have AE Pro is try adding the fog in post with the 3D Fog Effect.
    AdamT
    Cinema 4DXL8 Bodypaint
    *Remember: Tues. is national Shoe Day. Wear shoes to show your support for bimetalism and the designated hitter rule!*
  • Edgard Iriarte
    April 30, 2008 at 4:25 pm
    Thanks, but in my composite form C4D,where do i place the effect, on a null on a solid with some gradient. If you have any idea it will be awesome. Thanks
  • Adam Trachtenberg
    May 1, 2008 at 6:13 am
    I believe you actually have to render to .rla format (with depth option selected) in order to use the AE effect. Then you apply the effect to the .rla footage and it should detect the depth info. From there you have to play around with the start/end fog parameters to get the desired effect.
    AdamT
