Activity Forums Apple Final Cut Pro Legacy Fog effect behind objects!
  • Fog effect behind objects!
    Posted by Elliot Beach on May 31, 2012 at 9:42 am
    Hi there,
    I am very new to Motion and have not really used it at all, only doing a small amount of stabilization and that’s it. FCP and color I am more advanced if that helps. I am trying to create a fog effect in one of my shots and need it to appear behind some objects in the foreground [See images bellow].
    So I want the fog to be just above the water covering out the buildings and behind the trumpeter, pier and lamppost. One image in the original and the other is just a fog clip pulled over to give a rough idea for you.
    I’m sure its possible to do so can anyone give me a rough idea, name or tutorial that could help me with this. Thanks
    (I am posting this in Motion/AE forums as well to see which program would work the best)
    – Original
    – Fog screen pulled over
    Elliot Beach replied 14 years, 3 months ago 3 Members · 3 Replies
  • Mark Suszko
    May 31, 2012 at 1:56 pm
    You will need to make a mask around the dock and trumpeter. Then you put the fog in a midle layer of a3-layer “sandwich” of foreground, middle, and background. This can be done in FCP’s timeline, or using photoshop. There isn’t, AFAIK, a vector masking tool in Motion yet.
  • Michael Gissing
    June 1, 2012 at 3:04 am
    Hopefully the shot is static. AE is probably better at making and accurate mask around the foreground features.
  • Elliot Beach
    June 1, 2012 at 1:06 pm
    I ended up using AE and it has worked quite nicely with the help of some members here. Thanks guys
