Activity Forums Field Production Focus Issue
  • Focus Issue
    Posted by Simon De little on October 16, 2010 at 3:49 am
    When shooting a wedding recently the lens on my JVC HM700 came loose at a crucial time and the focus on the camera went very soft. I was wondering if there are any plugins or software that can rescue the footage at all? I edit in FCP7.
    Scott Rachal replied 15 years, 11 months ago 3 Members · 3 Replies
  • Fernando Mol
    October 16, 2010 at 4:33 am
    You can play with the contrast and add some noise to distract from the out of focus, but you will never get your focus back.
    Using a sharp filter will probably not work, but give it a try.
    I hope this helps
    *Always share a link to your site and rate the posts. This is a free service for you and for us.
  • Simon De little
    October 16, 2010 at 4:59 am
    cheers.. I’ll have a play around. I realise it’s pretty hopeless but I thought I’d put it out there in case anyone had designed some magic tool to fix it. You never know!
  • Scott Rachal
    October 17, 2010 at 1:16 am
    Depending on how out of focus your footage is, and how much running time you are talking about, try shrinking the footage.
    Maybe put a full-bleed, toned picture in the background, and have the footage in question play at 40-70% of full size. As the picture shrinks, it will look more in focus. (Once again-depending on how out of focus it is)
    Maybe put two shots on screen at the same time, both reduced in size? Depending on the content…
