Activity Forums Adobe After Effects Focal plane noise issue
  • Focal plane noise issue
    Posted by Michael Saul on April 3, 2012 at 6:48 pm
    Hi all,
    I’m experiencing a weird focal plane noise in AE CS4. I’m moving the camera across a jpg file newspaper headline,(high res, perfectly good file)The file is at an angle and the camera is using narrow depth of field to isolate a line of the headline in focus, but as the camera moves over the plane and the focus adjusts, I get weird, noisy grain between focus points. *See attached File. This is for a feature doc, so it will be projected.
    No matter what I do to the camera/focus settings, it doesn’t go away unless I turn off depth of field.
    Any ideas?
    Thanks much
    Michael
    Michael Saul replied 14 years, 5 months ago 2 Members · 2 Replies
  • Tudor “ted” jelescu
    April 4, 2012 at 9:01 am
    The attachment did not make it.
    You can try to use an adjustment layer with a animated feathered mask and a Camera Blur to replicate the effect without using DOF in the camera.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Michael Saul
    April 4, 2012 at 5:04 pm
    I know, I had a hard time getting the image to upload.
    Thanks, I’ll give that a try!
