Activity › Forums › Boris FX Particle Illusion › foam emitter in PI3
  • foam emitter in PI3
    Posted by Jim Woodruff on January 6, 2010 at 2:21 pm
    Does anyone know of a particular emitter in any of the current libraries that would look like foam? I’m thinking of the type of foam you would see from a “foaming bubbles” sort of bathroom cleaner / sprayer. I need to illustrate a drain cleaner foam that would travel down a straight section of pipe then dissipate.
    Thanks for any suggestions.
    Jim
    Graham Bernard replied 16 years, 8 months ago 3 Members · 3 Replies
  • Alan Lorence
    January 7, 2010 at 9:24 pm
    I tried making one in the just-released December emitter library.
    Alan.
    http://www.wondertouch.com
  • Jim Woodruff
    January 7, 2010 at 10:22 pm
    Alan,
    I downloaded the library and I think the emitter will give me a starting point to work from.
    Jim
  • Graham Bernard
    January 15, 2010 at 6:17 pm
    Alan! You have surpassed yourself! Excellent work.
    Those Blue and Orangy flames, blended together are amazing!
    Thank you,
    Grazie
