Activity Forums Adobe After Effects Foam as image replicator
  • Foam as image replicator
    Posted by Craig Sommerer on November 27, 2006 at 3:22 am
    I’m sure this is quite easy and I’m most likely overlooking something insanely simple. I’m using Foam as an image replicator. I’d like to set an initial number of “bubbles” at the beginning of the comp and not have any more “bubbles created or popped. I’ve been through all the controls and I’m not finding what I want. Any kicks in the proper direction to accomplish this would be greatly appreciated.
    Thanks.
    Craig Sommerer replied 19 years, 9 months ago 2 Members · 2 Replies
  • Chris Smith
    November 27, 2006 at 4:04 am
    You may have more luck using a particle generator to do the same thing like Particle Playground or best of all Particular.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Craig Sommerer
    November 27, 2006 at 9:25 pm
    thanks, chris.
    i ended up doing this in motion.
