Activity › Forums › Adobe After Effects › Flying thru Logos and having them with dimensions
Posted by Paul Meyer on May 22, 2007 at 12:56 pmIs it possible in AE to make logos have the dimensions to fly thru with a camera move? (zooming thru the letter O and seeing the curves on the inside of the letter)
Martti Ekstrand replied 19 years, 4 months ago 6 Members · 7 Replies -
Iancorey
May 22, 2007 at 1:56 pmShort answer: No.
Long answer: Eh… not really. Maybe, but no. You’d wanna do that in a 3D modeling program.
Paul Meyer
May 22, 2007 at 2:42 pmThank You. For both of your responses. It sounds as if 3D modeling program is the solution. A bit beyond my capabilities at this point.
Nico Jones
May 22, 2007 at 3:13 pmZaxwerks Invigorator will do exactly what you want – I’ve done the same thing a zillion times.
It’s cheap, relatively customisable, easy to use and made for precisely this kind of purpose. Go buy!
Rhett Robinson
May 22, 2007 at 8:42 pmYou’ll see it again and again… there are several free 3D apps out there that will do something like this with ease (especially if you add the AE panache to it to beautify your lack of 3D experience). Blender is REALLY powerful, but it’s unlike most other 3D apps, so the knowledge is not very transferable… well, the concepts are.
Anyway, until you’re ready to make the plunge, I’d try some of the free stuff – there are lots of generous folks out there!
Delete
May 23, 2007 at 7:50 pmCinema4D is one of the cheaper good 3d programs that’s fully AE compatible. You’ve seen it used for stuff like the Sports center-like tv transitions.
Nico Jones
May 24, 2007 at 3:34 pmBuying and learning cinema 4D when all you need to use it for is giving depth to the letter O seems a tad like overkill to me!
Martti Ekstrand
May 24, 2007 at 4:41 pmYup, it’s possible within AE without any additional plug-ins. Check out this tutorial right here on the Cow:
cheers
