Activity › Forums › Adobe After Effects Expressions › flying flies
flying flies
Posted by Sn1979c on April 29, 2006 at 1:49 pmHello I need some advice on how to make 100 flies fly arround a man in a black and white short film.
Do you know of any tutorial related with this topic I could do, or could you give me some tips.Thank you very much.
Eduardo
SN1979c
Andrew Shanks replied 20 years, 1 month ago 5 Members · 5 Replies -
Vince Becquiot
April 29, 2006 at 4:18 pmI saw a video once on Fly trainning:) (China I think)
I think that if you want “descent” results you’ll have to go 3D.
But, you could start with motion Sketch and the smoother.
Tutorial: https://www.creativecow.net/show.php?page=/articles/unguren_ben/motion_sketch/index.html
Cheers,
Vince
Sn1979c
April 29, 2006 at 4:25 pmDo you know of any tutorials on how to create particles move on a random way in an specific area of the screen?
Thank you for your help and your quick reply.
SN1979c
Julian Sixx
April 29, 2006 at 4:33 pmHi
Trapcode Particular has got a preset called t-swarm flies that may help you -
Mike Clasby
April 29, 2006 at 6:35 pmDan Ebberts had a nice swarming expression, wiggle really, on his web page, but alas
it looks like he lost his domain name, a sad day for expression hackers.This will work, not as elegantly as a particle system but quick and easy, you’ll know if you like the look
in no time.If the man isn’t moving it’s real easy with a wiggle expression. See below if you haven’t used expressions.
Put your fly (psd, or other file with transparency) where you want it to hover.
Alt + Click the Position Stopwatch for the fly layer, type (or paste) in this wiggle expression:wiggle (5,60)
Adjust the 5 – frequency (how often the fly changes direction, and 60 – amplitude(how far the fly goes before changing direction) to taste.
Duplicate the Fly layer (Ctrl D) as many times as you want flies, they will spread out a bit and all swarm around the man.
If the man moves, the quick way is:
Start with a new fly layer.
Make a new null layer (Layer>New>Null Object) and position it with keyframes to follow the man’s movement down the timeline, then Alt + click the Fly Position again, and pickwhip to the null position to get this:
thisComp.layer(“Null 1”).position
Add a dot “.”, and your wiggle expression to get:
thisComp.layer(“Null 2”).position.wiggle(5,60)
Dup the layer again, all should follow the null which is following the man.
You can also motion track the man’s head or something but is probably more complicated than you need since swarms are a bit sloppy by nature.
Andrew Shanks
April 30, 2006 at 7:11 pmI recently had to do a few shots with swarming bee’s attacking a couple of people. After trying a few things in After effects, I ended up using particle illusion to do the job, using a tiny photo of a bee for the particle shape then tweaking various settings until i got the right feel. Although i have not used Particular, you would probably get an even more convincing feel with it (being that it can work with your after effects 3d camera to give a convincing 3d perspective feel, ….my particle illusion bee’s were okay, the client was rapt, …but to me it did feel a bit 2d)
Goodluck!
andrew
