Activity Forums Maxon Cinema 4D Flying cameras and camera targets
  • Flying cameras and camera targets
    Posted by Simon Bronson on July 21, 2005 at 5:33 am
    I’m working on a single shot which features a car zooming over a bridge. I want to start with a reasonably static wideshot then fly in with a manic helipcopter like motion and lock onto my car.
    While the camera target feature is ideal for my closeup of the vehicle when i’m close, I don’t want it dictating my static wide. I’ve tried to nest a null within my car model compensating for the movement by starting it far then bringing closer but its not great.
    Ideally I want a mix of static camera and ‘locked on’ camera for this shot. Any ideas would be much appreciated.
    Here’s what I’ve done so far:
    https://www.zippyvideos.com/197650572672225.html
    thank you all in advance,
    simon
    Simon Bronson replied 21 years, 1 month ago 4 Members · 4 Replies
  • Adam Trachtenberg
    July 21, 2005 at 3:59 pm
    Hi Simon,
    You should check out the steady cam Xpresso setup that Lennart has put together. It’s an amazing piece of work and I think it would be perfect for your animation: https://forums.cgsociety.org/showthread.php?t=256818
  • Lennart Wåhlin
    July 21, 2005 at 7:43 pm
    Thanks Adam. Yes that would be very easy. I’ll upload version 78 later tonight, or possible tomorow (Current is 77). SteadyCAM78 have a -very- good option to use only parts of splines as Tracks. Makes animation/trimming even faster.
    Check:
    https://homepage.mac.com/tcastudios/TCA%20SteadyCAM.html
    Cheers
    Lennart
  • Chris Smith
    July 22, 2005 at 1:16 am
    Sounds perfect for the Parent constraint that Maya has. Where you can keyframe the mix between 2 different animations or constraints smoothly. I think Cactus Dan or someone has posted constraint plug-ins they made, one of them being parent.
    My other though is create 2 seperate animations and motion blend between them like using characters.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Simon Bronson
    July 22, 2005 at 1:23 am
    Wow, the Stedicam expresson plugin is AMAZING. Thanks alot Lennart @tcastudios!
    Now I want to go back and redo all of my other tracking shots.
    Thank you all kind cow folk,
    simon
