Activity › Forums › Adobe After Effects › Flying broken glasses
  • Ali Jassim
    September 22, 2016 at 8:42 pm
    You may achieve a result close to this in AE if you use a third party plugin called Element 3D from the creator https://www.videocopilot.net
    Ali
  • Kalleheikki Kannisto
    September 23, 2016 at 5:19 am
    The Shatter effect will give you something similar. With lots of tweaking you might get it looking realistic. That’s the free option.
    A complex (but free) option is to use the C4D lite that comes with AE. It is a 3D program, or a light version thereof like the name says.
    If you don’t mind getting plugins, I would recommend Element 3D. The glow in the center is Optical Flares, also a Video Copilot plugin.
    Senior Graphic Designer
  • Laurence Pesigan
    September 23, 2016 at 6:12 am
    Thanks for all the suggestions! I might try the free option first.
