Fly Out
Posted by Vegasarian on June 1, 2006 at 3:59 pmI have a small PiP centre of frame left. I would like it to 3D flyout to top right corner.When I apply Far X and Y positions the PiP only makes it to the bottom of top third of screen (Y axis) and not quite to the centre of frame (X Axis). This how it should be? …..anyone?.
Vegasarian replied 20 years, 2 months ago 4 Members · 10 Replies -
Terry Esslinger
June 1, 2006 at 4:38 pmI’m not sure about this, and I’m not at my editing machine to test it out, but you probably made the PiP with track motion so you have reduced the frame size and it is only flying around the reduced frame size. You might have to make it a child of a parent track (perhaps an empty track even) to get it to move around the entire full size frame? This is just a wild guess, wish I had Vegas installed at my office computer – but then I wouldn’t get anything done:>)
Gary Kleiner
June 1, 2006 at 4:54 pmAs Terry suggests,if you make the PIP with track motion, you are shrinking the boundaries of the frame. Try making the PIP using Pan/Crop, and your Fly Out transition should work just fine.
You could also create the Fly Out by keyframing the track motion.
Gary Kleiner
Learn Vegas and DVD Architect
http://www.VegasTrainingAndTools.com
Vegasarian
June 2, 2006 at 10:19 amWell….. tried that, same problem. The effect I’m trying to achieve is very close to the effect in GlenChungs post below…here….
https://annyandkent.com/slideshow1.htm
In my case my PiP fly out disappears under an invisble, horizontal line just under the girls eyes…..doesn’t make it right into the corner. -
Terry Esslinger
June 3, 2006 at 6:14 pmVegasarian
Post your email address in an answer to this post and I will send you a .veg file that shows you how to do what you want. Its easier than trying to explain it. -
Vegasarian
June 4, 2006 at 12:12 pmMany thanks for your help……..appreciated!.
toolbarr_toolbarr@hotmail.co.uk -
Terry Esslinger
June 4, 2006 at 3:56 pmHave sent you the .veg. It was made with V6 and I used stock generated media for the events. If this is what you are looking for you can study the .veg to see how it was done or you can put it on your time line and replace the generated media with your media, adjust the durations, etc. Good luck. Any questions, I’ll try to answer them.
Jgordon
June 4, 2006 at 10:06 pmHi Terry, Would you mind emailing me that same veggie that you sent to Vegasarian. I’m interested in it. Thanks -JG
email: jgordon*AT*lssincDOTus
remove the *AT* and DOT and replace with the corresponding chararacters.
Terry Esslinger
June 5, 2006 at 12:53 amJgordon,
Sure, except the address in your post does not work:>(
Jgordon
June 5, 2006 at 6:01 amI was trying to stop the bots from harvesting my address (it’s probably going to be harvested anyway but I don’t want to make it easy). I’ll try again as I don’t think I was clear. Put the @ sign before the first capitol letter. It should work.
jgordonLSSINC.us
Vegasarian
June 5, 2006 at 12:31 pmThat was it guys!.I was trying to do it in track motion. Works a treat in pan/crop….and just in time for my football World Cup Titles. (Its a game we get very excited about outside the USA!!). Many thanks for your help with the e-mail Terry.
