Activity Forums Adobe After Effects FLV Renders Skinny
  • FLV Renders Skinny
    Posted by Otto Bulut on February 13, 2012 at 10:08 pm
    Hello AE Elders!
    I am creating a 5min animation in AE that needs to be imported to Flash so some clickable web links can be added. My AE comp is 720 X 480. When I render it as a FLV to prepare it for Flash it gets squashed width-wise so that I must stretch it in Flash by W 110% to return it’s shape. This unfortunately creates verticle wiggles when the SWF is published.
    These FLV’s have black bands on the right and left with the image squashed horizontally. I honestly don’t know what could be doing this. I feel like I have done every combination of settings but maybe I am missing something. Compression isn’t my strong suit.
    I so appreciate any advice you might have!
    Otto
    Otto Bulut replied 14 years, 7 months ago 2 Members · 2 Replies
  • Angelo Lorenzo
    February 13, 2012 at 11:20 pm
    Check your pixel aspect ratio on both your comp and export settings. Seeing 720 X 480 makes me think you’re using NTSC with a pixel aspect ratio of .91 (slightly rectangular). You need to be setting this to square (may be listed as 1.0 or 1:1).
  • Otto Bulut
    February 14, 2012 at 12:52 am
    Angelo,
    You nailed it! Thanks for taking the time to set me straight!
    Otto
