Activity Forums Adobe After Effects FLV Output Module in AE7 Pro?
  • FLV Output Module in AE7 Pro?
    Posted by Spudnik187 on May 5, 2006 at 5:52 pm
    I was under the impression that AE7 Pro was going to give us the ability to batch export to flv through an output module template. I know I can export each individual composition individuall through the File/Export command, but I was able to do that in 6.5. Am I mistaken about this feature? I thought this was one of the big selling points of AE7 and, quite frankly, was the only reason I purchased 7. Can anyone help me out here? Thanks in advance.
    It’s always darkest just before it goes pitch black.
    Tim Kurkoski replied 20 years, 3 months ago 3 Members · 4 Replies
  • Sam Moulton
    May 7, 2006 at 5:21 am
    The preferences file contains the templates for output modules. Just make a copy.
  • Spudnik187
    May 7, 2006 at 6:39 am
    I’m not sure I follow. What does making a copy of a preferences file get me? My problem is I’m not seeing an FLV option in the output module dialogs. I’m only seeing it in the File/Export menu item.
  • Sam Moulton
    May 7, 2006 at 5:26 pm
    my bad… thought I was answering another post. As far as I can tell, only export gives your the flash movie option. Help files are no help on this one
  • Tim Kurkoski
    May 9, 2006 at 5:26 pm
    That’s correct, FLV export is only through File > Export, and not accessible through the render queue.
    The difference is that AE only shows QT plug-ins through the Export menu, and the FLV module bundled with AE7 is the same QuickTime plug-in that you get with Flash 8 Pro.
