Activity Forums Apple Final Cut Pro Legacy FLV glitches
  • Posted by Danny Fox on June 19, 2008 at 8:58 am
    Hi all,
    Have a quick time movie which I am now converting to FLV for a PC presentation. When I encode the QT to FLV, some horizontal flickers appear across the screen, normally on movement i.e. pans & zooms. As far as I can see these flickers are not on the original QT file so it must be something to do with the conversion to FLV. I have tried using the noise removal settings on my encoding package but this doesnt seem to solve it, if not making it worse.
    Does anyone have any ideas?
    Danny
    Danny Fox replied 18 years, 2 months ago 2 Members · 2 Replies
  • Phil Holbrook
    June 19, 2008 at 1:38 pm
    Are you exporting right out of FCP w/ adobe flash installed or what program are you using?
    Phil
  • Danny Fox
    June 20, 2008 at 8:16 am
    I export the original QT movie from FCP. Don’t know if Adobe Flash is installed within this. How do you do this?
    The QT file is then put through Cleaner 5 to convert it to FLV.
